Does any one have any good step by step how to about this subject , pics,links, items list anyhting welcome. And yes i searched damn it!!!!
another thing to add is after the final sanding i just used mothers aluminum polish and steel wool, then moved down by hand to the polish and soft cotton cloth, it seemed to work well, made a good almost mirror finish and i did it with a dremel and hand sanding instead of the drills with sanding wheels, but if you go the drill route you will need an assortment of fine tips in every grit you are using because you will find it hard to hit all the fine and hard to reach sections, it seems easy until you start polishing, but it is not too hard. i also recommend buying a used one and finishing it before you take the car apart just in case it takes you a while.
