i think i am right in guessing the waste gate spring is set at around 6 psi ???
if this is the case if you are going to be running the same boost say 12 psi all the time would it be better to remove the solinoid and put an external spring across the wastegate arm so it effectively has a 12 psi spring in it ?
this way there is no spiking as a bleed valve cuses
just a constant 12 psi ????
or does a dwans control have no spike ???
my mechanic had to maunually open the waste gate cause i was going through turbos like happy meals. the turbo was staying at a constant 12psi
