hey all i was trying to search around on water\meth injection for the 1st gen cant find any thing so my questions are has anyone done this?? how big off a diffrence have you seen and is it worth doing????
Meth injection is well worth it, helps considerably in reducing knock and detonation, allows you to run higher boost levels more safely, and keep the intake charge temperatures much cooler. I love meth! :p
thanks guys ive always wanted to do this on my first 6 i had and now that i got another i am deffenitly going to.
ademen you used a holly pump correct??? what model is it???
you can use a windshield resourvior and pump if you wish
There are certain washer pumps that will push 70psi quite hapilly.
A little research should find you the actual part #'s
