Hello everyone,
It looks like I ran into a problem while trying to install my water pump. I manage to take the power steering pump and the a few bolts from the water pump (upper part of the timing cover), but it looks like I'm stuck at the crankshaft pulley at the very bottom of the wheel. I'm using a belt wrench to hold the pulley from moving while trying to unbolt the nut, but it doesn't seem like it want to get loose. I tried using a torque wrench as well, but not luck. Now I'm trying to use an impact wrench with my 15 gallon compressor but it doesn't seem to work as well. Should I get a new compressor? It's pushing 150psi max and 90psi to the gun and the gun is 550lbs of torque, is this enough pressure at the gun???
I refer to the haynes manual as well as the board, but Still can't seem to get it off. Any suggestion fellow mx6er.
Thanx
Thanx
