Has anyone had oil puddle slightly on top of the transmission? The most obvious thing in that area is the rubber and metal clutch lines, but they are dry. The metal hardline for the turbo oil supply are a possibility that I need to look at more closely. The valve cover gasket is new and I see no evidence that it has failed anywhere near enough to cause this issue. I will add that the leak does not reveal itself unless I am driving it, that makes it much harder to detect the leak source. Finally, I thought maybe the throttle body could be the source, but from taking all of the hoses and boots off I see nowhere near enough oil residue to match what's on top of the transmission.
This car continues to be an enigma and just a total PITA!
