I noticed tonight that my when I put it into Neutral it automatically goes down to about 1250rpms as idle...you wait about a minute and it goes down to the correct idle speed. Anyone have any ideas?
Check your TPS setting. It may be off a bit and not triggering the idle switch.
Jump the TEN and GND and see if the fan kicks in. If it does, then the TPS is not set correctly.
Follow Rick's manual TPS adjustment page to guide you in the setting of the TPS.
http://www.rs-productions.com/RSP_Motors/tech/tps/tps.htm
