1 - 14 of 14 Posts
This topic is one of the most popular on other car forums I'm on, and I thought it might give a place for some of us who are doing work (or cleaning or driving or whatever), but not a major build to talk about what you're doing.
The prior owner of my car had installed a trunk with a spoiler, but didn't put in the lifts that could handle it, so I finally fixed that problem. I also fixed the trunk pull... I'd tried bending the tab, but I was afraid of breaking it, so I made an extension out if epoxy and painted it black (I also painted over the junkyard number on the latch).
13057
Today I replaced all of the clips that hold the door shells on. They now feel so much more solid when they close.
I would love to hear what other people are up to....
Sadly, my MX6 is just sitting, waiting for a part. Specifically, a new exhaust/resonator (it's rusting out, at the flange where it joins the muffler). None available (that I could find). WrenchMonkey say they can get one from Borla sometime in July, so I ordered it. If that fails, I'm going to have to ask my neighbour if he will fabricate one for me (he makes stainless steel exhaust systems as a hobby).
Discussion Starter #3
Sucks that it's sitting. I feel your pain. I should be able to finally register it on Monday if the DMV actually opens... Then a proper test drive (assuming I fix the clutch hydraulics between now and then).
Be sure to report back on the exhaust. I want a full stainless system, but finding out what it's going to sound like is challenging!!
Discussion Starter #4
Finally got the clutch hydraulics fixed. After replacing the master and slave cylinders, it just kept bleeding fine, then bleeding air (or nothing, it was hard to tell if my vacuum pump was just leaking or what). I couldn't figure it out, so I set aside an hour or two to pull it all apart and test each piece individually.... it turned out there's something in the reservoir preventing the clutch master from picking up fluid once it's halfway between full and low, and it starts drawing air at that point... you can kind of see it in this picture, where the back of the reservoir is lower than the front:
13059
Is that normal? I assume not, but I have no idea...
I have a vague memory (don't trust me on this) that dual brake/clutch hydraulic systems are set up so that if the clutch system leaks, it doesn't take all the fluid out of the brake system. For safety. So I think it may be normal.
Discussion Starter #6
Well,I'm willing to hope so.... at least, it all works great as long as I keep the reservoir over that level, so for now, I shall do just that~
As to what I'm doing with the MX6.... not today, but yesterday I started my timing belt/water pump replacement. I am stalled at the moment though, as I found the harmonic balancer and motor mount were in rather sad shape after I took them off and ordered new parts. I also managed to snap the power steering tensioner bolt so I'll be picking up a replacement for that too...
You snapped the power steering tensioner bolt ? That is a little unusual since that just continually rotates and not fastened tightly against anything. Where are you going to locate a replacement ?
That power steering tensioner pulley is an unusual one. The open face has to face away from the engine for it to run smooth. And either way, the clearance between the pulley and crankshaft pulley is almost nothing.
Did you loosen the power steering pulley bolt before starting to move the power steering tensioner bolt ? If not, that would have created tension and could have caused the bolt to break.
Discussion Starter #9
That is exactly the mistake I made... I should be able to get any M8x1.25 bolt that's long enough (checking advance tomorrow).
As soon as I get that bolt and more coolant tomorrow, the motor mount and harmonic balancer are supposed to arrive Tuesday, NJ MVC finally reopens Tuesday, I should actually be able to get some real miles in this week!
Discussion Starter #10
I would just like to say that I hate engine mounts. It just didn't want to be in the right spot, and stupid me hsd removed the jack handle so I didn't trip over it, making it really hard to adjust the engine position at all.
The bastard is in, though. Hopefully my post-timing belt start is tomorrow.
What did you do to your MX6 today..?
Nothing. Can't get it started. Its been parked since mid May while Ive been recuperating. Jump started it a couple of weeks ago and now won t turn over again even with a jump. Nothing's happening..no clicking, nothing. Not sure what the problem is now. Tried different Ground points for the Neg but no luck..!! Confused .
Discussion Starter #12
I'd try taking out the battery and getting it tested, so you at least know how bad it is. I've had times where the battery was so low that jumping didn't really do anything. Or I had to leave the "good" car running for 5 min first before trying to start the "dead" car. That would at least let you see if anything changes.
Discussion Starter #13
For me, today... I buttoned up my timing job and found out I probably have the belt off by a tooth... it'll start, but runs terribly and gets worse + backfires I rev it at all. So I pushed it out of the garage to make room for woodworking projects for a bit... I'll get back to it when there's a chance of actually being able to get the title transferred and registered. Has anyone seen the news on how bad NJ DMVs are? ugh.
1 - 14 of 14 Posts
