1 - 9 of 9 Posts
yea ive just been driving around in my 2g after a few months of it sitting in my garage and i have noticed some noises coming from the front wheels
it particulaly does ti when i put the brake on but it does it other times too eg when the car is slowing without brakes or driving at a sub 50 k speed~
when i put my head out and listen to it more clearly it sounds like its coming from the front wheels
i am thinking i need some new brake pads and probably a service checkup to be safe
just some questions as i havent personaly done any of these b4
if it is brake pads: how much to buy them and get someone to install roughly, or is it easy to do/
if it isnt brake pads: what might it be :eek:
how much would a service be generally, ball park figure :p
what is another good thing to upgrade while im at it
car is at 210k's
thanks
whats the noise like ?
could be glazed pads/rotors.
rotors will need a skim if within specification. which is around $40 a side.
pads just clean them up with some sand paper if still have meat on them.
Discussion Starter #3
its hard to describe this noise lol
but its just like metal to metal
and its in a loop playback kinda thing which flows with the wheel
high pitched sorta
its not excessivly loud but you can notice it if you are nearby
check the condition of your front brake rotors and pads. thats the first i would look at
yeah the pads could be worn it could just be the wear indicators scraping so you know to replace..
Probably the brake pads dragging on the discs? My Cressida is doing it too, and the MX6 did it before I took it to a brake specialist.
Discussion Starter #7
turns out some power steering fan belt ors oemthing is broken
and my brake pads are worn
getting it fixed on thurs for about 300
If the belt is broken you would have noticed it. Either the AC & Power steering would not work (you would notice) or the waterpump or alternator would not work (you wouldn't be going far). I suspect worn/cracking rather than broken. I think the belts were about $30 simmilar for parts. They are easy to do yourself.
Pads can vary in price but generally $100-150 fitted if I remember correctly & about $70 for disc machining - which is probably where the real noise is coming from as everyone suggested.
I am having the same problem in my 94' Ford telstar only thing is i just got the brake pads done. its only been making it since we got em changed. I enquired about machinine but they said it would b fine. Its annoying if your driving around slow in town as ppl around can hear it. :damnmad:
1 - 9 of 9 Posts
