Okay IM slow I just removed the drivers seat to check the abs computer but theres no box I can feel soemthign under the carpet with wires going to it...IS that it???
Discussion Starter · #2 ·
Coudl the computer be onn the passanger side?? I noticed to seperate units on that side the power steering and soemthing else.....
Tell me if this sounds plausable...becuase the tx5's dont have 4ws (the unit for the 4WS that would usually go on the passanger side is not there) there for the abs unit for the tx5 is put next to the power steering unit on the passanger side....soudn right? How to identify the abs unit? SO I can tell if Im right??
4WS ecu is taken by the ECPS ECU under passenger seat.
the onyl thing udner drivers seat from memory is a 4WS pump relay and 1 other small ECU
for the timer relay etc 4ws only
abs is under passenger seat
thanks rod I think the reason I was getting confused it cause I was looking at the US manual of course the abs would then be under the drivers seat hence why its says to remove the drivers seat to get to the abs...THanks
