okay so i installed the disty and guess what it did nothin to help my problems... i pulled my codes b/c the light actually stayed on this time
i got these
01 ignition pulse(my guess i have to align the disty right??)
08 vane airflow signal(is this the vaf? or Maf?)
16 Egr valve position sensor
can you tell me if this would prevent my car from starting... making it hard to start after it warms up.. im ready to trash this car its drivin me insane...
EGR wouldnt make your car not start. VAF i would start by checking to see if its plugged in all the way or try another one.
y ai will install the original one tonight... i bought another one but i though tit was better but maybe not
Keep us updated. Like Maff said check the VAF, for the EGR check the vacuum line that goes to the air box. That line needs ambient air, I found out the hard way. And don't forget to reset the ECU before you try to start the car.
Good Luck
