I have a KLZE IM on my port matched KLDE head/engine, so what TB is the best to use? Should I use a DE TB or KLZE TB and what are the downsides/benefits for either?
Ze mani doesn't have the nipple for the cold idle hose I don't think, electrically they should be the same as far as the ECU cares
Use KLZE Idle control and KLZE throttlebody...
I see you are in Richmond, BC... I am Burnaby area and can advise you more in depth. KLDE throttle body can even be modified to work with a ZE IAC
