1 - 8 of 8 Posts
1996 Mazda mX6 v6 5spd.
I went to a parts desk yesterday to ask a lady how much it would be for an 02 sensor for my car..she said there was four of them and each are around $200....
Well, that HAS to be a lie becuase i cant even find one.
How many 02 sensors are there for this car and where are they located?
well, i got these codes when i brot it to a shop.
can someone help me out?
What it needs
and what i can do?
and what risk it will pose?
This is waht was written down for me on the peice of paper.
P0443 ( I searched on the internet and could not find this code)
Evap Purge Control valve.
P1770
02 Sensor
P1195 ( this is the tricky one)
EGR Boost sensor
OR
BARO sensor circut.
What id like to know is
1.Do I replace or clean
2. how much does this part cost
3.What is the name of the exact part that i need if it needs to be replaced
4. What is the last code..what do i do, what is the part..etc. basicaly ..WTF.
thanks in advanced.
Im asking this becuase im sending it to a shop, to get all this fixed. i want to know everything for my self also so he duznt end up charging me every last dime in my pocket.
yes, you do have 4 because you have a 96, which is obdII. you have one on each header after the pre cat converter, so that's two already. then you have one on each part of the y pipe where the headers connect to, so there's your 4.
I believe you will need two 3 wire o2 sensors and two 4 wire o2 sensors. get them from rockauto.com if you don't want to rip yourself off by going to a dealer. these will cost around 43-44 bucks each from rockauto before shipping. there are also 5% off coupons floating around for rockauto all the time.
the other stuff, i don't know about
well, which code will tell me which exact 02 sensor needs to be replaced?
do i have the right code here? p1770?
Josh Bannings = 1
From what I can tell, P1770 is a clutch solenoid problem, not an o2 sensor. You shouldn't even have that code because it's for an ATX.
Josh Bannings = 1
Are you sure it isn't P1170?
P1170 HO2S Bank 1 Sensor 1 Circuit Fixed (Bank 1 Sensor 1)?
Discussion Starter · #6 · (Edited)
oops
yeah
on the paper it says p1170
so it is what you just said HO2S Bank 1 sensor...so which 02 sensor is that?
Okay i did some research, i figure out it is one of the first set of 02 sensors, right on the manifold, not the two that are right before the cat?
i also figure out that this sensor could malfunction due to a leak in exhaust? my exhaust had a leak in it right at the connection for the cat and the piping afterwards, almost as if a gasket was missing. I used muffler cement and sealed up most of the exh, should resetting the ECU after sealing the exhaust fix this?
i also have a fear in resetting the ecu becuase i have this thought in my mind that if you reset it while having bad sensors..you may just screw up the car...bcuz i had an 02 sensor code with my 93 integra, and i reset the ecu for a different reason, and that same morning, the car sputtered and died and nobody could figure out why... so.. i dont know if i should.
I know eventually im going to have to, but i dont want to do it unless there is a huge possibility that the code wont show up
I also have a hissing noise from somewhere in the car, i thought it was the exhaust but it turns out its not becuase when i sealed it up the noise is still there, its a slight whistle so im also assuming a vaccum leak?
could anybody tell me what i could do ?
A vac leak can cause codes, so find that leak! There are a couple of ways to find leaks including spraying starter fluid around the motor to see where a leak exists, but in your case, since you can hear it, just take a vac diagram (you can find it on this site), and follow all the vac lines to ensure they are all plugged into the right spots and there are no tears.
Discussion Starter · #8 · (Edited)
okay what im going to do is light a mach then blow it out and wach where the smoke goes...is that a smart idea? becuase i looked inside the hood and everything looked attached.
i need to find a brick if im going to leave the car running while i look for a leak becuase the car has no e brake.
1 - 8 of 8 Posts
