right then.... not that i'm in any position to be doing it yet, but... couple things i'm wondering about doing a widebody. ok, i get the part about making the fenders, etc. (i figure if you used fiberglass it might not be excessively heavy). but what about widening the wheel base (i mean the track)? you can only widen the actual wheels so much on the inside before you start to rub, otherwise you gotta screw with the offset, which isn't ideal. wheel spacers will only get you so far before you stress the wheel bearings/ball joints... ("wait, how wide are you going, pal?") so i figure you'd hafta extend the axles, modify the suspension, sway bars, control arms, etc, while maintaining proper suspension geometry... or am i just making it more complicated than it really is?
...coldnoodle, deejayarse, how are your projects coming along? what have you had to do so far?
