i have a cel coming on...its the egr valve position sensor. I tested the valve, it seemed to work properly. Im going to clean it in a bit. But, the other thing is....while testing the egr (sucking through the vacuum hose) the idle will drop....good. Now, after the idle drops...it will come back up to normal and stay.....then, if i rev the motor....the idle will stick at 1k. Does anyone know what could cause this? vac leak somewhere? Or, is it the EGR itself?
*EDIT* When im on the throttle, driving down the road...the cel will go out. When i let up and the car bogs down...the light comes on.
