if i swap a klze engine into my ls will it pass emissions inspection?
will it pass md state inspection? thanx
I cant see why it wouldnt. You still need a functional catalytic converter to be legal in MD and they will check.
i WOULD NOT COUNT ON IT. mD is kinda strict, plus your ecm is not us spec>>>
well if you fail and you show proof of repairs for at least like 300 bucks then they might let you pass. just buy a new cat, and change all your filters. go in there with clean oil and your gas close to E. Also if you have the a-spec ecu then i think your engine will be running lean anyways.
Eternal College Student
I second all of this. Even without the EGR system, if you do what he said, there is a decent chance you will pass. If not, it's not too too hard to tap it and make one.
I know this will not help the KLZE question. Today I took my MX-6 to get the emissions inspection and I got a 2 year waiver because my car was too low for the dyno machine at the place. They said that I needed a flat bay. I did not argue with them I got my paper work and had my Jeep tested and passed. When the next 2 years come up I can get another waiver unless they have the flat bay dyno machine installed.
