Ok, I need to get an amp for my Audiobahn sub before the 10th so, times running out.
-Here are the specs for the Kenwood amp I found and the link: http://cgi.ebay.com/KENWOOD-KAC7202-920w-2-CHANNEL-CAR-AMPLIFIER-BASS-AMP_W0QQitemZ5834919411QQcategoryZ39734QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
KENWOOD KAC7202 920w
150 x 2 watts RMS @ 4 ohms
230 x 2 watts @ 2 ohms
460 watts RMS x 1 bridged output
Built-In high pass and low pass crossovers
selectable bass boost (0-18 dB at 40 Hz)
Built-In high powered cooling fan
MOS-FET power supply
C--E--A-2006 compliant
preamp + speaker level inputs
preamp outputs
Tri-way capable
<LI>13-5/8"W x 2-5/16"H x 11-1/4"D
My Subwoofer, Audiobahn AW1206T
http://www.crutchfield.com/S-JnwgH6f1BL6/cgi-bin/ProdView.asp?g=520&I=037AW1206T
12" subwoofer with dual 4-ohm voice coils
aluminum woofer cone with 2" foam surround
non-resonant cast aluminum basket with polished chrome plating
7-1/2 pound magnet
frequency response: 20-500 Hz
power range: 50-1,100 watts RMS (550 watts per coil)
peak power handling: 2,200 watts
sensitivity: 96.4 dB
top-mount depth: 7"
sealed box volume: 0.5 to 1.25 cubic feet
<LI>ported box volume: 1.3 to 3.2 cubic feet
Ok the Question, will this amp work my sub? I hope so, A yes or No and explaining it would be awesome. Sorry guys for asking so many questions, Let me know thanks :)
Or what kenwood would work if it doesn't?
it would work but you can go a bit bigger if you'd like for not too much more.. and since we're sticking with kenwood.......
Kenwood KAC-9102D will get you up to 850 watts rms at 2ohms instead of your 460. Little more bump. They sell it at bestbuy... thats the only reason why i know this. Go bribe someone working there to buy it for you with their discount.. they'll probably get it for like $150.
