Guest
·I dreamed this up at work the other day, and I don't know much about the subject so this is probably wrong.
Anyways I was mulling over the Honda VTEC system (what little I know of it). If you don't know how it works: 2 sets of "lumps" on the camshaft, 2 for low rpm, one for high rpm, with the high-rpm located between the low rpm ones. The high rpm lump has a greater radius from the center of the camshaftEach triplet corresponds to one valve, and each lump has a lifter that it strikes. During idle and low rpm, the low rpm lumps strike the low rpm lifters, which are attached to the valve. When the revs reach a certain point, say 4000 rpm, hydraulic pressure caused by the increased revs slides a bolt through the single high rpm lifter, which attaches it to the valve. That means the high-rpm lump comes into play, and you get increased airflow because of the increased duration and uhhh, i don't know the other one. Anyways, that's why VTEC engines are such screamers at high rpm, because they have switched over to more aggressive cams. Some of this is probably wrong, but you get the general idea.
So anyways, I was thinking this was pretty complicated, and there should be a simpler way of doing this. So, instead of messing round with hydraulic bolts and different lumps, why not move the camshaft itself closer to the lifters? At idle and low rpms, the camshaft would be at it's furthest point, and therefore the lifts would be at the least duration and extent. As revs increase, the camshaft would be moved progressively closer to the lifters buy some hydraulic pressure or something. This would increase the duration of the lifts as well as the extent of the lifts because the lumps would be striking the lifters sooner, for a longer period, and move them a further distance outward. It would function much the same way as the bigger lumps on the VTEC camshaft. An advantage of this over VTEC is that it's a lot simpler plus it's continuously and infinitely variable.
Now, I figure someone has either already thought of this, or it's completely unfeasable for some reason or another. Hopefully Mike93PGT can give me some answers as the resident tech-guru. But hey, if I thought of putting Air in the front of shoes before Nike did, then I can think of this right?
