1 - 11 of 11 Posts
I'm getting constant noise form both A pillars over 40mph. Having done some head scratching as the door seals are both in excellent condition I decided to check the windscreen seals.
This is a pic of what I found, seems like the seal has contracted slightly whereas it looks like the two halfs should be locked together. Gap is 3-4mm. This is the same on both sides at about the same point. Firstly do you think this could be giving me wind noise? is it just a case of reseating the seal?
thanks, i was looking for the weatherstriping for the front... i would karma but i did you not to long ago..
I'll tape it up first to see if the noise goes away, then I'll order the new strip. btw guys I'm uk based and I can't find a uk supplier. Any ideas as to how's it's fitted
1 - 11 of 11 Posts
