1 - 9 of 9 Posts
My 93 MX6 seems to have a problem with removing condensation from the windows. It seems that if its moist outside the heat only removes the condensation on the lower half on the windshield and barely off the doors. Is this a common problem or could it be a undectable problem with my heater. I haven't noticed it not working correctly.
there is stuff you can get, Rainex i believe that makes it, but it comes in a like a windex bottle, spray it on and you won't have that problem ever again
another thing to watch is the Air recirculation button. it works even if you dont have air con. It means that it stops fresh air coming into car and so can just re circulate humid air. But yes, wind the windows down as well if its on the outside as well.
i know the stuff. its in a little yellow bottle and you rub it on the inside and outside of the car. on the inside it stops condensation from forming, but on the outside it makes a layer on the window where water just rolls off. after using it, even in quite heavy rain i didnt need to use windscreen wipers
1 - 9 of 9 Posts
