What I meant is I have a dented door I'm throwing away, I've strippedmost useful bits and pieces the only other thing I thought might be worth keeping is the electric window motor, I'm asking is it easy to remove?
Not hard. Be careful removing the door panel, the clips are not that sturdy.
Save the side controls for the windows and the side view mirror. These go for good money on ebay.
You need a ten mm box wrench to losen the 4 bolts that hold the window in place, and some patience in working out the motor.
Remove the motor and regulator as a unit.
The regulator is what the motor and glass are attached too. It is what moves the window up and down, or "regulates" the movement.
It has wires and pulleys attached to it.
