1 - 10 of 10 Posts
ok this might sound retard but i want 2 attempt this mod. I want 2 make my wiper arm spray out washer fluid. The reason why i want this is because i dont want 2 drilll washer nozzle holes into my c/f hood.. I'm getting tired of stopping & gas station cleaning my windshield.. any input on this.. I know there is a few options here....
1. Drill Holes
2. replace with OEM hood
3. keep doing what i'm doing lol...
4. Wiper arm mod.
Thx for reading...
look for buick, cavaliers and others Gm's sprinklers. also, i think ford made some too. they attach directly on to the wiper arm. the tubing is not so complicated. 1/4 vacuum tubbing and couplers: you should spend about 50 bucks max.
also though about fitting the sprinklers in the plastic between the hood and the windshield(srry i dont know the name of the piece).
dont know if it can help you... Good luck!
Bud, why are u driving with a CF hood in the winter anyways? :confused:
just run a hose + a TEE and zip tie a hose on each arm...
or put the spray nozzles in the cowel plastic
well i figured out what 2 do i was walking through the parking of my work & i saw the parts truck Van it has clip on washer nozzles. it's a plastic clip that holds the nozzles on the wiper arms.. the clips are off of a 05 GMC Salvanna Van i called chev. cant buy the clips alone gotta buy the whole freaking arm assembly. lame!
Wrecker... but i wouldn't like the hose attached to the wiper arm... ugly and lame.
make a sprayer that is on the cowel molding. Or even like a 1970 chevy truck had a sprayer nozzle made from aprox 3/16 metal tube with a pinched V end which came through the cowel.
eBay Motors: 1964,65,66 THUNDERBIRD WINDSHIELD WASHER JET NOZZLE (item 220340737954 end time Jan-13-09 17:27:18 PST)
eBay Motors: 1973-80 CK10-30 BLAZER JIMMY WASHER SPRAY NOZZLE NOS GM (item 270329196399 end time Jan-18-09 16:57:22 PST)
you dont see alot of the hose i didn't even really noticed the hose till i looked closly you only see like 3" of tubing it's only for the winter time~
Mount the OEM sprayers in the wiper cowling. That's easier to do then anything your thinking of.
they sell aftermarket sprayer kits at crappy tire... or at least they used to... just clip on to the wiper arm.. I bought one when i busted one of them on my sunfire back in the day.
and it will be easily removable come spring
1 - 10 of 10 Posts
