okay,
so i brought an S13 Silvia. Jspec corse :)
one thing i didn't notice while test driving the way, if you go over a bump or sewer drain thing in the middle of the road it feels like the back end is kicking out, or moving a little bit - crabbing.
Now, the tyers are pretty much shocked, 2mm above the worn bar.
the power steering pump has a very very smell leak. but i dont think thats the problem...
I've replaced the tyers since, and still have the problem.
I have taken the car to a suspension specialist - Pedders.
They seem to think its the Hub Assembly which, if you've ever seen one, they would be very very very hard to bend.
The toe is in 20MM. so its alot.
Pedders also said its not a lower control arm or anything like that which if the hub was bent, surely it would have bent the other parts connected to it.
wired.
any other input?
My z24 did the exact same thing... One of the shocks on the rear were shot. Fixed that, and everything is nice again!
