Hey guys, Im writing here as it´s probably the best site for MX6s/Probes and Im desperate.
I have 1993 Ford Probe GT (V6 KLDE) that won´t rev past 5500 RPM. But it did before! I replaced my valve cover gaskets and obviously I screwed something up.
I read codes from memory and got a bunch of them, so I starterd to chew through them. Now, my memory is clear and I don´t get any check engine light, but it still won´t rev past 5500 RPM.
I replaced my distributor with spare one, had the timing adjusted with timing light and the TPS as well. It didn´t help.
I replaced both coolant sensors (Fan and ECU one, not the dash one with single pin). It didn´t help.
I replaced the plugs and wires. It didn´t help.
Some time before this, about a year ago I also replaced my fuel filter.
I had a single code left after all this. #5, the knock sensor... And yeah, I admit it, I accidently ripped the wires when taking off the manifold.
I fixed the wires, cleaned the memory and went for a drive. The code is gone.
Now I have no codes when I read the memory, no flashing or glowing check engine light, but I still can´t rev past 5500 RPM! :-(
I had some opinions given on my problem by other guys from our community, they suggested:
1) To replace the solenoid on air intake. Already did that.
2) To replace the Fuel pressure regulator (I didn´t do that yet)
3) To replace my spark plugs, as apparently, while I did buy NGK ones, the ones I got are "Too cold".
What do you guys think I should do? Can the signal from Knock sensor be distorted because of the wire accident?
