Has any1 else had the problem of there car not starting in the rain? it cranks but just does not kick over. i found out that inside the car above the back windows is damp after some heavy rain.
Any ideas what could be causing this thanks :)
disty is going. ignitor is being finicky. uncle had the same problem until he did an hei/external coil mod. starts up first time everytime now
Your distributor cap seal is probably done for, moisture is getting into the cap. Get new cap + seal, fixed the problem for me
I agree with this as a first try.
What would the ignitor have to do with moisture unless you're just trying to overcome the moisture on the cap points.
