mx6
Hey man... I have a mx6 that i have built but need to get ride of cuz im movin across the pond......
Im asking $9,000 for it but i can move around...
the car is pretty built it has,
the car has 185,839 miles on the body.
it has a newley rebuilt motor with 300 miles on it!
the motor was built by HBC Motorsports, it has je pistons bored .30 over with 8.7/1 compression with je chromolly rings, new stock rods, new forged crank(micropolished) and the bottom end was balanced and blueprinted along with hot tank, milled (.008), finally a coat of 1,500 degree coat of black paint.
The head is new, it has new valves (with three angle valve job) new lifters, new custom camshaft (270/276).
the head also has a stage three port and polish.
it has a new turbo (.53).
the motor has a new oil pump, water pump, timing belt, timing tensioner pulley, newer alternator, newer powersteering pump, msd coil, k&n filter, 420cc probe injectors, new fuel rail, all new vacuum hoses and fuel lines, braided stainless steal turbo oil line, ngk spark plugs and wires, all new ground wires and I/O starter wire, new stock intercooler, new stock bypass valve, ACT stage2 clutch kit, rebuilt tranny with about 4500 miles(previous owner), used recalibrated maf, intake was gasket matched and polished, throttle body was cleaned and polished, 3" catback straight pipe.
The exterior of the car is in good shape.
The undercarrage was coated with rubberized undercoating. There is rust on the driver qp behind the molding, and on the trunk under the wing. there was a hood scoop put in the hood(which is primer black). The car has brand new tires with only 500 miles on them. It has 626 tail lights.
The interior is in great shape. It has a couple stains on the driver seat but there not big. The car comes with another set of interior panels. The carpet has no stains. The dash has a rip in it above the cluster!
The car will come with an alpine CDA-7893 cd player, colby 7" lcd in dash monitor, pioneer 140w front speakers, pioneer 240w gold series rear speakers, bazooka 10" sub with custom box(made for the car), 2 jenson amps(front 88w,sub 300w), a vr3 amp(rear 200w), a 500k half farad cap, rockford fosgate and sosche wiring. also apc steering wheel, autometer boost and oil pressure guages in A pillar pods, and a pace setter short throw shifter.
The car is pushing 15lbs and is estimated to push just above 200hp
(will dyno upon request $100 charge)
The car (with the last motor with same parts) runs a 12.8 in the qm.
The car has not seen the track nor has never been jumped on!!!
If any questions or more pic request please call or e-mail me...Thanks
(740)739-1801/[email protected]
millage is subject to change. and i am forgetting some things so i will add when thought of....
