Ok, I'm getting the ****s with this annoying noise I have. It sounds like it is coming from the front right hand wheel. I've narrowed the following info down.
- It only happens while moving... not just revving the engine.
- It sounds like a grinding noise... metal on metal.
- It happens in all gears.
- It happens going forward, backwards and turning corners.
- Grinding increases with speed, not RPM.
- It is not the CV's
Ok, here is what I have done so far....
- The exhaust is completely clear of everthing (over an inch) and is very well supported... it is only 3 months old.
- All the belts etc are clear.
- There is nothing lose in the steering or drive train.
- The tyre is on properly.
Here is the thing, I think it is that stupid ABS sensor on the cog of the drive train. I took it off and gave it a clean and it seemed to make a little (not much) difference. I thought it was a little cog in a big one at first, but it isn't! It seems to be a magnetic sensor that just sits above the cog and picks it up the larger cogs movement.
Now, I don't know how to take it off, or move it so that I can test drive without it. Has anyone else had a problem with this thing? Or do you think it might be something else? Do these need to touch the cog to work? If I don't I might lift it up off the cog with some washers.
Tripharn
Tripharn
