ZE TB gasket
657 Views 4 Replies 4 Participants Last post by  Fastest95PGT
Is the ZE throttle body gasket the same as a DE? I am going to need one for when I install my 67mm ZE TB and straight neck intake manifold. I know that for the IM gaskets I can use 2.5 millenia gaskets with the straight neck ZE but I am not sure about the throttle body gasket.
I used a stock gasket.
They are the same :tup:
Stoof01 is correct. :tup:
Doesn't hurt to toss a thin bead of RTV on both sides of the gasket when installing. This is more important if you re-use the old gasket as I have done many times. Even when installing a new gasket, it doesn't hurt. Save you from doing the job twice.
