Ok i figured mostly everything out for hooking up
the zex nos. But how do I hook into the fuel
pressure regulator and the intake manifold. I have
a mx-6 parts book to help. And the direction for
the nos are very clear.Please help. Thanks
Ok. I know on Mustangs and most other cars the fuel regulator goes between the fuel pump and the fuel line's entrence into the throttle body. You probably will have to mount it to you firewall. Does it have a manual adjustment or is it electornically controled? Let me know and I will get back to you.
Alright. Look at the fittings on the side. If two you need to mount it like I thought. If is just one then I am not too sure. But it will go to the throttle bottle. What type of nos system are you using?
