61 - 71 of 71 Posts
Discussion starter · #61 ·
The pistons are different & so is the IP. The head & injectors are the same. The engines are so over engineered that the NA engine is fine to be lightly boosted. The head is the limiting factor in any case.
I would not worry, I would just bolt the turbo manifolds onto the R2. Boost control is via the internal wastegate. On a diesel though boost is really controlled by fuel, the wastegate is just there for protection for over boost.
The turbo injector pump has an aneroid chamber which is connected to the turbo outlet so it senses when the turbo is boosting and increases the stroke to inject more fuel.
However, when the aftermarket turbos are fitted, the tuners simply increase the governor fuel amount & maximum fuel amount. It works, the downside is that if you floor it before the turbo is on boost you get a black smoke dump. If you ease onto the power it its not so bad.
With the turbo IP, the aneroid allows the engine to come onto boost before adding the extra fuel. This is also why the wastegate is needed. More fuel would keep building more boost which then increases the fuel until the wastegate opens.
Using the NA pump, the fuel has a set limit, so no wastegate is needed.
Discussion starter · #63 ·
I would leave the R2 head on the R2 block, why swap a head which is essentially the same unless there is a problem with the one that is on there now. Save your RF-T head as a spare and just swap the turbo, manifolds & IP if you have the RF-T IP.
The only thing to be wary of; the R2 block is about an inch taller than the RF, so anything from the turbo that connects to the block might need to be modified a little.
Eid Mubarak (best wishes for the best holy day)
Today I replaced engine oil pan with original B2200 ones and hope it will not leak again.
But I saw some oil drops near intake manifold where rubber intake hose meets with metal pipe which is attached to intake manifold with 2 bolts .
removed it and oh there's more oil.
I fixed it back applying silicone sealant to stop oil seepage but what to do now?
Is it blow by and if so how to tackle?
Compression check? Valve seals check or piston rings change?
Discussion starter · #65 ·
A little bit of blow by is normal along with some oil migration.
If it worries you, do a compression check. Not sure what the limit is for an R2 but 384psi is the lower limit on an RF.
If the compression is low - yes rings will need to be changed & the bore honed at least. It depends on how worn the bores are as to whether you would get away with just a hone or a re bore.
R2 motors come as two types; some blocks are cast as one piece and some have replaceable cylinder liners. The former would need to be bored out to the next oversize and the pistons replaced. The latter would just need new liners pressed in.
The advantage of replaceable cylinder liners is that you don't need to replace pistons due to oversized bore
Don't have compression tester but will try to find it on any workshop
Engine doesn't reduce a single drop of oil even after 5k km and no loss in power too
just wanted to say this is a great threat, recently bought a 4th gen B series ute/94 ford courier with an R2 engine and was having a hell of a time finding much info but after reading this threat i now feel more familiar with my own engine
have had some fun with fixing problems caused by at least 1 previous owner with the electrics for the rear/dash lights being fried and hacked apart
after finding various bits here and there on the tail end I've come to the conclusion someone jack knifed a trailer pinching the tail lights wiring then put over rated fuses in till they burnt stuff out. have since properly replaced/patched most of the damaged wiring in the dash and running to the tail lights, only electrical issue left is the reverse lights still don't come on, think its the sensor/switch in the gear box has failed but have yet to trace it
second issue was the radiator appears to have had something dropped on its outlet pipe causing cracking around it so i have re soldered it and now the temp hardly passes the 'cold' point on the gauge under normal driving conditions instead of sitting in the middle and slowly eating water (50km drive would need another 2L of water put in)
while i had the engine partially apart for the radiator repair i also took the bus bar off the glow plugs and measured their resistance which was 1-1.5 Ohms each drawing a total of about 750w (from memory)
the battery is at least 10 years old and very much on its last legs,seems to have at least one weak/dead cell which makes it a pain to start on cold mornings or after short trips so will be getting a new one soon
also a past owner put a racing steering wheel on a utility truck that has no power steering and a tare weight of over 1 metric ton and over sized rear wheel rims and lower profile tyres yet front are stock as a rock which makes replacing tyres a painfully expensive exercise
Mazda R 2 diesel in Asia Rocsta
Hi
I have a ping which sounds like a diesel ping when I speed up at about 70km .
I rechecked my injector pump and I found 2 marks on pully. A 1 and also next a + mark.
Which is the correct mark. It is a NA engine. It also lacks power . Battle to get to 90km And ping go slightly away if I ease of accelerator.
I just bought it and guy has just fitted a new head and injectors.
Hello all, I too bought one of those 2006-ish "Mazda Bongo Brawny 2.0L Turbo Diesel powertrains." It is connected to a RWD Automatic tranny and transfer case. It came with an ECU. The package was all complete including accessories, wiring, etc. I've had it for a couple years in storage, waiting for the right Bronco II or ranger to put it into. No luck with it so far. At this point, there are several "know-it-alls" that have tidbits of erroneous information, that have NEVER touched one of these, so be careful. Like Terrawombat, I too have some firsthand information on MINE ONLY. I have not gotten around to unwrapping it and setting it up on a stand. I had intended to install the entire package under a 4x4 ford. I since have discovered, that the Mazda has a switch on the dash that I will need to get, that simply has an "+RF" on it. The ECU sees this and will not work without it. It is for a front electronic diff lock-out. There are several other things including the fact that the ECU controls the injections of each cylinder. This one function is quite complex, timing no less than 17 pulses, per cylinder, each rotation... Now 2 years or so since I bought it, I am still "almost there" in trying to get a service manual and a compatible scanner for it. I have read countless reviews translated from several countries, where this engine can produce anywhere from 97 HP, to 173+ HP with the right program on the ECU. And those same folks are boasting mileages from 29 MPG, to as high as 54 MPG, (no coasting.) From what I have been able to discover, Mazda, in the Bongo installation uses an intercooler out front of the radiator, on a slant to conform to the rake of the front body contour. I am still trying to get a Japanese service and overhaul manual. I have a Japanese foster sister that can translate it for a small fortune. Sooo close, and yet so far... Anyway, if there was a person younger than me and willing to buy this project, I'd not be too hard to deal with.
61 - 71 of 71 Posts
